Hi Guys,
Right, just before Christmas, i bled some of my radiators & discovered that the water was very black (i have a conventional (Traditional) Boiler System).
The last time the system was drained was in 2007 & this was done by a plumber who was taking out a radiator.
So, I just wanted to make sure I'm doing this right (i cant afford a plumber at the moment & i'm pretty sure its a simply task).
1. Shut off water & turn off the central heating system.
2. Attach a drain hose to downstairs rad - luckily i have a rad right next to my back door with a drainage valve/tap.
3. Open drain valve on rad & allow water to drain.
4. Once water has drained away open the bleeding valves on the upstairs radiators followed by the downstairs ones to allow any access water that is left to drain away.
5. Once water is drained away close all the bleeding valves & close the drain tap & remove drain hose.
6. Add Sludge Remover to the system into the radiator header tank - now this is the small one in the loft NOT the large one isnt it?? (quite important not to get this wrong! ) I've been told to use this treatment to dissolve any sludge that may have gathered in the pipes etc.
7. Turn water back on & allow system to fill up. Bleed rads to allow water to fill them up.
8. Once the system is filled up & all rads are bled turn Central heating back on.
9. After four weeks of running the central heating system, repeat the process but this time add the normal inhibitor
So, is this ok?
Cheers.
edit: Would X800 be better than X400 for removing gunge/deposits.
btw, the CH system it about 14 years old.
So, is this ok?
Cheers.
