Good compost heap
12 Dec 2016
The guys I work for put leaves and horse manure in their compost heap. What is the best to do one of these?
mix it up well and turn it in spring, putting edges to middle. It is an advantage to have two or more heaps, so that you can turn that one into another bin to finish off, and be using the contents of the third bin while you fill the first. Unless the garden is large, you can mix all the materials, including grass cuttings. They will rot better and faster mixed up.
Leaves contain little nutrient but are good for the soil texture. You can stack them separately, in which case they will be cold and slow to decay.
It is more usual to have a separate muck heap, it will heat up and rot quickly. It's ready when dry, dark brown or black, and crumbly with no offensive odour. Do not leave it so long that it goes grey in the middle. If you have plenty you can then mulch thickly with it, and the worms will dig it in for you. Strawy muck is smelly; woodshavings muck is not.
If you have space, separate heaps / bins for leaves are recommended. I believe its also useful to get them quite wet - if you think about piles of leaves "in the wild", in dry weather very dry leaves just blow around and crumble while wet rained-on leaves turn into something that looks like compost quite quickly.
Put damp leaves into black rubbish bags, really ram them in and tie off, next year you will have the best compost ever.
