grab ring mdpe to 15 copper
4 Apr 2010
Humberside
Hey I have a reducer to go in to a 20mm mdpe tee to reduce to 15mm copper. Does any on know which way the coned grab ring should face? So is its like an arrow on the pipe going towards the fitting or the other way so its like an arrow pointing towards the pipe. Hope that makes sense.
check the "nut" part- you should see it's tapered. the insert corresponds and as you tighten up it grips the pipe.
