Part H table 2 & diag 3. Gradient limits for unvented branch pipes.
I understand the reason to put a maximum gradient on - to avoid unsealing traps.
(eg washbaisin on 40mm can achieve maximum of 3M on 18mm/M)
Is is correct to assume that if the pipe must turn completely vertical for part of a run before the stack, then that's not exceeding the guideline?
