Hi All
I think I know the answer to this one, but just want to explore all options before facing a painful bill.
I have a Grant 70/90 multipass, sealed system oil condensing boiler. It was installed about 17 years ago. Water locally is very soft and not aggressive.
Boiler has started to leak small pool of water underneath. It's floor standing and difficult to get to, so hard to do any easy investigation. I'm coaxing it to run at the moment by re-pressurising and bleeding off the air.
I'm guessing the jacket has failed and the boiler is probably US, but before I condem it is there anything else that's worth investigating. Assume it has a heat exchanger (?) but can't seem to find an exploded diagram. Presumably once the burner and cover was off this would be easy to check.
Any ideas, or am I just kidding myself and need to fork out £1500 plus fitting....Gulp
