Calling all Heating Engineers
Have a Grant Combi 90 oil boiler which was installed approx 10 years ago.
The boiler decided to spew its contents onto the kitchen floor recently and a heating engineer confirmed that the boiler had corroded and was beyond economical repair.
There are 3 connections to the top left hand side of the boiler and one larger connection on the bottom left hand side. It is this bottom connection which has corroded. From the manual it would appear to be the central heating return.
I believe that it should be possible to remove the outer casing and have the boiler welded to repair this corrosion however the heating engineer who looked at it said that the boiler was beyond economical repair.
I can appreciate that there may be considerable labour involved in removing the tank from the casing hence the suggestion of a new boiler.
I work as a mechanic and am fairly confident that I have the ability to strip the boiler down and fabricate the tank myself (although I can't see the extent of the corrosion for the outer casing at the moment). The boiler's knacked at the moment anyway so nothing would be lost if I was opening up a can of worms.
Would I be embarking on a road to nowhere or from your collective experience would you consider this repair possible? I can upload photos if you think it worthwhile. Obviously if the repair was successful I'd get a heating engineer to check it out and recommission prior to using.
Cheers.
Cheers.
