- Joined
- 27 Jul 2021
- Messages
- 7
- Reaction score
- 3
- Country
I had a new Grant Vortex Combi 26 boiler installed 1 year ago. I also bought a Hive thermostat and wired it in myself. Having never owned a combi boiler before I thought all was well. Central heating came on when I wanted and I had hot water.
Then I realised that although I could get hot water, it was only when the heating was on. Simply turning on the hot water tap does not fire up the boiler.
This is what I've done/tried so far...
I wired the hive (terminals 1 and 3) into the 2 room stat terminals (and removed that loop).
I have removed the timed CH and timed DHW loops.
The hot water switch is in the 'timer' position.
When I turn on the hot water tap all the lights come on as you would expect - Flow, Demand and DHW Pump but the boiler does not fire up. With those lights all lighting up I assume that the water pressure is good and the flow switch is working ok. Like I said this is pretty much a brand new boiler.
If I change the hot water switch to 'constant' it fires up straight away so that works - but obviously I don't want my boiler running 24/7.
If I replace the wiring loop back on to the DHW is will fire up when the hot water switch is in the 'timer' position - but again I don't want the boiler running 24/7.
Any ideas?
Any ideas?
