Hi
Was looking for some advice.
As above have a Grant Multipass, about 12 years old. I have to say it's been excellent. A couple of years ago when the boiler first fired up after being on holiday for a week it was a bit noisy for the first minute or two and that was it.
Over the past week it has started to get noisy though. Sounds like bearings/fan. Today I took the cover off, convinced myself it was at the fan end of the motor shaft> so I took the fan cover off, not visible sign of fan touching anything, no play in bearings, didn't feel rough to spin.
Put it back together, and tried it just to check, and it was just as noisy. But now the heating has come on it seems no noise.
The only thing I can think of it that the oil in the tank was very very low this week, the noise started on Monday, we had oil delivered on Tuesday. Tank is 6ft below boiler so it has quite a bit to draw.
Maybe the pump sucked up some water/rubbish, or it had an air block. Having the burner out and disturbing it cleared it or moved the air so it bled through ?
Anyone have any ideas, been running now for 40 mins without drama !
