Grant Oilies
27 Jan 2004
Can anybody tell me the difference between the Grant euroflame and the Grant multipass" boiler house boilers" apart from the BTU range.
Secondly is there any pros/cons between them?
Thanks all
Would you care to elaborate a little further Wilhem?
mmm. not really.
you get what you pay for......... as in everything in life.
:eek:
Well wilhelm has certainly demonstrated his expert knowledge there then.
The Multipass boiler is slightly higher efficiency, but this means the heat exchanger is bigger and so the boiler is bigger than the Euroflame. Only by an inch wider, until you get to the biggest multipass, for which there is no Euroflame equivalent.
The multipass is front access servicing/cleaning, and the Euroflame is top access.
As for the "get something else" comment, Grant boilers use Riello burners, and these are among the best available, the rest of the boiler is just a steel heat exchanger, so there isn't a problem. People making comments like this are worse than useless unless they can support their assertions.
