Hi all - my external Grant combi vortex 26 oil boiler has started to randomly cause the hot water demand LED to briefly flash on and off which results in the boiler trying to heat up for a fraction of a second, in a short burst of 5 to 10 attempts. It usually calms down after a while (once something warms up I guess)
First thought was flow switch messing about, I disconnected that but no change - Demand LED continues to randomly blink on which causes relay to click and DHW Led comes on and the burner fires up very briefly. All connectors seems ok on PCB, tapping the board / relays doesn't show up anything suspect.
I'm thinking it could be intermittent relay on the PCB or the PCB at fault?
Hot water and central heating are working OK other than heating gets interupted when the boiler thinks hot water is needed and does the above odd random behaviour for 2 mins.
Any thoughts appreciated.
