Graphics card for 300w PSU?
1 Nov 2005
Middlesex
Hi all,could somebody recommend graphics card to run with a 300watt PSU,i have got available a Pcie x16(and others) slot,not sure how easy it is to change PSU so any advice would be helpful
many thanks Terry
Hi Terrymalc,
Its usually extremely easy to change the psu in an average PC case.
You just need to make sure the motherboard connector type is the same (adapters are avaliable)
Uprate your PSU and then you can buy a graphics card fit for your purpose rather than limiting yourself
Hi Disinfo,and thanks for the advice,would you know the best places to buy a psu and graphics card
Terry
Ill second cclonline, use them for both home and work, never had any complaints, delivery quick.
Going to fit an XFX Geforce 210 graphics,will run ok with the 300w psu,also going to add more memory,your views on the graphics card would be helpful.Also should i fit both upgrades at the same time,or should i fit memory,re-boot,then fit the graphics,re-boot ect
Many thanks Terry
