I live in a top floor flat in a converted Edwardian house and have a problem with my shower pressure running off a combi boiler.
Mostly (daytime and evenings) the shower pressure is ok, not great, but in the mornings it often dribbles with lack of pressure for upwards of 15minutes. I think this maybe to do with people in the other flats below taking showers at the same time thus decreasing mains pressure.
Currently my boiler runs directly from mains, and I've had two plumbers round to investigate the problem/come up with a solution (at £100 call out each) and both have very different solutions:
1- New conventional boiler + pressurized hot water cylinder (£4.5k)
2- Pump between my boiler and shower (£500)
The first is too expensive and seems to be overkill for a 2-bed flat with 4No. radiators total. The second I've read is illegal/dangerous??
I think all I need is a cold water gravity tank with a pump creating a new feed to my current boiler (admittedly its a pretty basic 'Main 24kW' but it seems ok).
Can anyone advise the best solution? I really don't want to pay ANOTHER plumber for questionable advice!
Many thanks.
Many thanks.
