Gravity Fed, QE2 Controller and need wireless
1 Oct 2007
Manchester
Hi
I currently have a gravity fed system with a Grasslin QE2 Controller. Whats the easiest way to add a wireless room thermostat - wall mounted?
Any help or guidance would be greatly appreciated!
Steve
A simple rf room stat such as the honeywell analogue stat or the Drayton Digistat 1 would suffice on your system.
All that is needed is a permanent live, neutral and a switched live that comes from the timer to the base unit then back to the pump live.
Sorry, the basic honeywell analogue stat is wireless as well ;) Can't think of its code at the moment :oops:
fantastic! thats the one then!
Just to clarify... as our system is old, you can only have heat & water at the same time, or just water...
It'll still be ok with that right? and will just control heating?!
Thanks for your help!
