Hi - I intend to install a gravity fed shower into my new constructed downstairs ensuite (did a a garage conversion). The house is over 3 floors with the hw tank on ground floor and the cold water storage in the loft (4 storeys apart). The issue I face is that the cold water system is direct and therefore the closest cold water supply from the tank is that which feeds the hot water tank. Can I tee a 15mm feed into this for the shower or will this substantially impact the HW performance. I intend of fitting a standard shower head to restrict the shower flow rate.
Appreciate you thoughts.
