Good afternoon all,
I have a gravity fed hot water system supplying a mixer tap in my bath with a shower head attachment. The cold water pressure is obviously a lot higher then the hot, as with the hot tap fully open, the cold tap only needs to be cracked open ever so slightly to get a reasonable water temperature from the shower head. Opening the cold tap any further results in a completely cold shower, I suspect the cold pressure is backfeeding and pushing the hot water back to the tank.
I am proposing to fit a pressure equalisation valve such as this one http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2334197
in an attempt to equalise the pressure and so hopefully give some control over temperature, without fluctuation that is also present at the moment.
I was also considering installing a check valve in the hot water line to stop the cold water pushing the hot back to the tank, is this advisable or necessary?
Any comments are welcomed, thank you for reading.
