Hi
We have just replaced our carpet floor tiles in the bathroom with the Florentine Blue Tile Loc Wooden Floor from B&Q, yes it was a pain to fit, but when it came to the beading, obviously wooden beading doesn't bend round the toilet and sink, so heres a great idea which someone else told us about.
Thought it might be useful for all you flooring DIYers out there.
We used 12mm sisal rope (bought from B&Q for 54p a metre), we dyed it using cold water dye (by Dylon) with salt and dye fix, then when it was completely dry, we measured each piece to fit where it needed to go, cut it (of course it unravelled slightly so All Purpose Glue was used to glue the ends - my hands got covered in glue so this is a messy job).
The glued ends of the rope were then left to dry again and once dry were cut across the ends (only a small amount) to create a flat end and then we were off.
First of all we sealed the gaps around the edges of the wooden floor with coloured silicone sealant and then we glued the rope down with the silicone and put panel pins in every so often to hold the rope down until the silicone dried.
Once this was done and the silicone had dried, we took the panel pins we could get at (could be left in I suppose) and then the rope was coated with a clear coat of Yacht Varnish.
It looks lovely, a bit different, and makes a change from wooden beading.
Once I have taken piccies, I will put one on here to show you the effect.
We have now got the kitchen to do with light chestnut flooring, so we are going to use the rope again, maybe either left un-coloured or coloured brown.
Hope some of you find this tip useful.
Catherine
Catherine
