We're renovating our two bathrooms that currently have a suspended timber floor with old chipboard 19mm T&G boards that are in a bit of a state, ie it'll need removing and replacing to get a sound base to tile onto.
I'd planned to go with 18mm WBP ply, but the builder we've been talking to about doing the work is proposing to use green chipboard instead - is that better or worse than WBP ply?
Also - for the walls - the existing plasterboard is almost certainly going to fall to bits when the tiles are chipped off, so I'd like to replace it - we'll use the waterproof tile backer board around the shower (WEDI?) but is it OK to use regular plasterboard for the other walls? or should we use the backer board on all the walls? or WBP?
Finally, as a bit of an aside, any ideas how much we should be paying for the work. They are small-ish bathrooms (about 4 sq metres each) but a bit of a job since the loo and soil are moving to the other side of the room in each case, the new WCs will be wall hung with a boxed in cistern and frame, the bath and shower mixers are concealed, etc. and as mentioned the floors (and prob wallboard) need replacing. Oh, and a 1m section of the (stud) wall is being moved and a doorway moved.
We've been quoted roughly £7,000 in total (excl VAT) for the installation (incl. plumbing work, floors, walls, boxing in, moving the doorway, tiling) - excluding the sanitaryware, taps, bath, shower, and the tiles. Does that sound about right?
