Green rust on radiator pipe..pls advise
1 Sep 2009
Middlesex
Hello,
Recently noticed a bit green dripping under one of the copper radiator pipes in the bathroom radiator grill.
The joint is not wet to touch and there is no constant drip as yet..!! I did not try to scrape in case I spring a leak causing chaos..!!
Please look at the photos and advise me if I should get this fixed asap..!!!
//www.diynot.com/network/SIDD/
Thanks in advance.. :)
I think the simple answer is yes, looking at that pipe it isn't going to be long before it starts leaking, it needs cutting out & replacing
Hmm hope your copper pipe underground is wrapped properly, all looks a bit poor there.
Gawd, that looks manky. Are you insured for complete replacement of all rotten old pipework installed by a plumber who didn't wipe off the flux after finishing the joints?
