- Joined
- 2 Dec 2004
- Messages
- 552
- Reaction score
- 4
- Country
Hi all,
I have just over a 6ft by 6ft slabbed area where I wanted to put an alumnium greenhouse. The slabs, while flush with each other, are not level as a whole. The whole thing slopes into one corner so the height difference will be maybe 1 to 1.5 inches over the 6ft distance.
Not knowing how these greenhouse bases fix, is it possible to level the base using shims before attaching the frame? Or can the base sit unlevel with the frame screwed to it level? Or does the slabbed surface HAVE to be level?
The slabs are loose layed on about 2" of sharp sand. Under this there is another layer of slabs directly on soil (I did this because I wanted to use up some slabs and the 'hole' was about 5" deep. So I put a rough layer of slabs down, then 2" sand then a better finished layer of slabs). The ground itself slopes hence why the new finish also slopes.
Cheers
Cheers
