Hi all,
Got a W.Bosch Greenstar 24i junior.
Been having trouble lately with CH pressure dropping to zero continually after each use. Having placed a carrier bag over the outdoor pressure relief pipe I found that this was collecting a large amount of water and obviously is therefore the location where the system is loosing pressure.
I checked the expansion vessel pressure. This was quite low so i topped it up to the Manufacturer recommended 0.75 bar after de-pressurizing the CH system first.
I then refilled the CH system to 1bar having bled all rads as part of the process.
Re-powered the boiler and turned on heating with CH level set to 5. As the system warms up the pressure rises to just 3bar at which point the pressure relief outlet starts to slowly trickle water.
So even with the pressure in the expansion vessel set correctly I still have water coming though the relief outlet.
My understanding is that this should not happen (stay dry) when functioning correctly? If this is the case, Does anyone have any ideas or suggested checks to see where the fault may lie?
I have an engineer coming to look at this but not until next Friday. If there were a simple fix or even somebody that can give me the heads up on the likely work that will be required before the engineers visit that would be appreciated.
Thank you for reading and any time taken to reply..
Cheers.
Rick85
Cheers.
Rick85
