Hi
In central heating the boiler is absolutely fine.
When we run any hot water tap you hear a whining sound from the boiler much like water running through or past a blockage.
As you increase the flow on the tap it starts to cause a vibration in a pipe, I assume, which sounds like a drum beat (dub dub dub dub best I can describe it lol).
The frequency of this can be changed my increasing the flow, this increases the rate of the sound or decreasing the flow which reduces the sound.
If you keep the flow slow you avoid the sound and if you open the tap fully you eventually get past the resonance and the sound disappears.
If you open the cold tap while the hot is running that will reduce or eliminate the sound also i'm thinking this is due to the mains pressure falling which runs through the boiler.
I was wondering if anyone could shed some light on this please driving us mad. The whining sound made me think maybe a deposit in the turbine or that area ? or possibly the turbine has broken down causing a obstruction ?
Any thoughts suggestions appreciated!
Cheers
Cheers
