Known this boiler 24i for years. Gas safe certificate every year. Here is history over last few weeks; That engineer has been out but is intent on
replacing 'all sensors' and going down the parts list until solved.
Nice Fella though!
Output starts very hot then goes cold on DHW supply, particularly bath and shower. Can go OK for 2 minutes to 5 minutes then go cold, boiler shuts down.
Suspected gunge in system, so introduced suitable chemicals for a few days.
No difference. Boiler not in limescale problem area.
Diverter valve seems ok. Boiler ignites OK. Pressure OK but not checked expansion vessel pressure.
Boiler continued with hot and cold routine.
Changed Thermistor for new one. Seemed OK overnight but now getting very hot then shutting down. However...…..if the shower or bath supply is
quickly adjusted so that it does not have chance to get very hot by introducing cold water it can go long enough for normal bathroom use.
My logic? If it can run OK with water temperature controlled to acceptable level by balancing cold water output then that eliminates water flow sensor, thermistor, and what else?
Your help appreciated please, Cheers, John. (shaken not stirred).
Nice Fella though!
