Thanks for the advice.The tabs would ideally rest flat onto the wall, if theres not enough wall , then what i do, usually with surface boxes, but would work with flush boxes, is slip some thin 4mm washers over the screws then you can get the grid yoke tight and not flapping about, it may take a few goes fitting the cover on and off till you get the spacing right
what depth backboxes are recommended?
