I have a Richmond Lighting/Zano Grid500 push dimmer switch module running three recessed 12v 35w tungsten recessed ceiling lights. One bulb has blown and the others are pulsing.
The remaining load of 70w is still well above the dimmer's rated minimum of 40w. Before I buy a new bulb, is there likely to be a problem with the dimmer itself?
If I need a new dimmer, how easy would it be to switch the whole arrangement to LEDs? I do not have easy access through the upstairs floorboards in order to fit a compatible transformer.
Any advice would be greatly appreciated,
Alec.
Alec.
