Grill is mucking about
5 Jan 2003
Essex
Electrolux Oven Model EOD5310
The grills full or half sometime work or not at all, where do I start or what is the most common problem, element, switch or thermostat ????
Could be poor connection on element. Bad connection on switch, the grill switch could also be on the back of the thermostat.
Intermitents are the difficult ones, there isnt much wiring to worry about but switch off & do a physical check first, if you have a meter so much the better.
SWITCH POWER OFF.
Thanks Diyisfun,
After checking with a multimeter, it was the thermostat cut out on the back of the grill, got one on order, 3-4 days.
