Hi all,
Trying to see if I can get to the bottom of a problem I'm having with my Grohe shower.
Up until a couple of weeks ago the shower as working fine but now it seems that the water goes cold after a few minutes of use.
Using one of the remotes (batteries are fine in both) we turn the shower on and after a few minutes the shower will get up to temperature, so the temperature setting will stop blinking and makes the sound it does. It then runs for a few minutes fine then the water goes cold. To get it going we have to turn it off then turn it on, it gets up to temperature and runs for a few minutes and the water goes cold again. Rinse and repeat!!!
Am aware the problem could be boiler related as the hot water is supplied from the combi boiler but running hot water via any of the taps in the house doesn't cause the problem.
There are no error codes displayed on the main controller in the shower.
Any recommendations or suggestions as to what might be the issue or things that I can look into will be gratefully received.
Thanks for the help.
