Grohe Thermo Shower Mixer with s-coupler....
3 Sep 2006
OK what does this connect up to?
I am installing a shower cubicle across the end of a narrow room. I have built two stud partition walls each side making up to the width of the shower. After taking some advice on this forum I am going to line with aquapanel. This will then be tiled over with porcelain tiles.
The pipes run up one wall behind one of the partitions.
It looks like I should connect the s-coupler to a 15mm compression / 1/2" female fitting but this would be in the depth of the aquapanel / tiles and so all but impossible to fit.
Any suggestions?
