Hi all,
Looking for a bit of advice. I want to install a ground anchor in my shed, its sat on a concrete base, but my shed floor is around 2 inches from the concrete base.
I'm going to cut out a square in the floor, then I was going to box it off and fill with more concrete, then drill through both the new concrete and existing base and install resin fixing bolts.
My other idea to make life a bit easier is to cut a square and just place 2 concrete commons side by side, drill through these and the existing base using the same technique? Good / bad idea?
