Hello,
Is there a maximum depth below floor level a ground beam can be cast?
The reason for asking is there need to be waste pipes which would pass right through the ground beam, obviously weakening the beam and probably causing the waste pipe problems in the future.
If i install the beam lower in the ground i can run the waste pipe over the ground beam and the brick/block will be built over it with a lintel.
I did ask a foundation company and they said 'we would advise you move the waste pipe', which was not very helpful as i can only make s**t run downhill and mains drains invert is mains drains.
