Basically... is the concept feasable?
The reason i ask is that i have a ground floor flat, hence no access to the ceiling space from above. So instead of hacking lots of lovley holes in the ceiling to run a new loop-in lighting ring I thought you could use junction boxes under the floor.
That would mean the power for the lighting running under the floorboards and then the switch cable runs up the wall to the switch in the same channel as the power to the lamp in the ceiling.
Does this sound daft or has it been done/seen in the past?
Anyone know of any compliance issues provided all cable run correctly in walls?
Thanks in advance
Thanks in advance
