I have a query relating to using the slab method. I'm looking at the cheapest option for a detached self & to get an accurate price for both options, The ground floor total area including internal garage equals 125m2, 30m2 for the garage and 95m2 for the house. I've got a price for beams with infill blocks.
The garage will be slab floor anyway, but I'm unsure on the remaining 95m2 of the house. I've done smaller slabs before by myself, but not on the scale of a full house.
On a full house with 4 large ground floor rooms, how is the 150mm sub base put in place, along with the sand blinding and then 100mm of concrete, is a digger required to load everything in? How is the concrete put in when a pump isn't used, (No one really uses pumps locally) The additional labour or digger hire could make a slab more expensive than beam & block. As mentioned, i still need to use the slab for the garage regardless.
