Some time ago I posted a question about my ground floor with some pics, and was asked to find out what kind of floor was currently in place.
While some local builders were in this week I showed them some of the material I'd dug out of the "slab" from which the sub-floor is made. They said it was most likely to be a mix of "lime and cinder" which has then been covered with a thin layer of bituminous material and floorboards nailed down over that.
I want to remove these boards as they are in a sorry state through wear, not really through moisture related issues. When I pull them up though the removal of the nails will damage the bituminous layer which is acting as a surface DPM I guess.
I intend to create a new wooden sub-floor layer over the lime & cinder on top of which I will then fit solid oak. The advice I am after obtaining is:-
DPM? Do I need to apply a new one if the bituminous layer becomes damaged?
Foams/underlays? Are they worth putting down under the wooden sub-floor I intend to fit?
Board material for the sub floor - ply/chip?
I was considering the following course of action:-
Rip up old boards and remove nails from lime/cinder slab
Fill holes/gaps with self-levelling compound
Install a combi-underlay (DPM backed foam)
Sit the ply/chip on top (but I dunno how I'd hold it down?)
Any advice on this would be extremely helpful, thank you.
