Hi All
We are renovating a 1980s built house and intend to fit UFH throughout.
In the existing part of the house the floor is made up of 4" of hardcore, DPM layer, 4" concrete with 2" screed over the top.
Given that there is no insulation in the existing floor will overlay UFH in EPS panels work ok or is the heat leaching into the uninsulated existing floor going to make it inefficient / ineffective?
Would I be better off removing the 2" of screed and lay 50mm EPS panels with the pipe routes cut in them for the UFH, then put 20mm dry screed boards over this then the engineered timber on top of that.
If anyone has any advice I would be most appreciative!
