Hello everyone,
I've just read about rebar (reinforcement in concrete foundations) being used as an electrical earth in the USA. Apparently it's in their equivalent of the 17th Edition:
"it turns out that rebar in concrete footings or the foundation for a house is actually a more effective grounding system than the ground rods we've been using for decades. So if there's rebar in the new footings, that rebar needs to be used as the primary grounding electrode. In a nutshell, if a new home has footings with at least 20 ft. of 1/2-in. rebar, the rebar embedded in those footings needs to be used as the primary grounding electrode. This new provision in the National Electrical Code"
http://www.familyhandyman.com/elect...common-electrical-code-violations-diyers-make (no.
From my scant knowledge on the subject, that seems strange; rebar is steel and liable to rust easier than copper grounding rods. OK when it's embedded in concrete it shouldn't rust; but then is it contacting the earth? how conductive is dry concrete? (let's assume the concrete is isolated from the surrounding earth by a plastic membrane).
Also what about the connection between the copper used in building wiring and the steel rebar; isn't this going to corrode (more) quickly due to the potential between different metals (see https://en.wikipedia.org/wiki/Galvanic_corrosion)?
I would like to hear your opinions on this which, as it's in the "Code", must have been discussed by our colleagues across the pond...
Thank you in advance!
