I have been looking into installing a rw harvesting system for toilets, washer and garden watering, but as the garden rises away from the house would have to bury the tank very low to get a fall on the pipes.
Last night I dug a test hole, and hit the water table 1300mm down (sand and gravel) - this after a very dry spring, and it occurred to me I need a well or borehole.
Has anyone any experience of this - I want something midway between an expensive 10m drilled hole and a bucket on a string - with a pump and filter etc?
I know there are issues about replenishment. I had wondered about using soakaway crates surrounded by geotextile (Aqualoc or Waterloc) to create an underground sump with a pipe going in to extract. Alternatively just dig deeper and install a wellhead.
Would it be better just to draw water as needed, or to have a header tank in order to overcome the replenishment problem.
Any advice, experience, contacts, where to buy would be much appreciated.
