Hi all, just fitted the tiles and grouted in the bathroom.
Around the shower area we used weber-joint http://www.netweber.co.uk/tile-fixing/weber-products/products/joint-tile-grouts/weberjoint-wall.html , (with Sovereign Super Grip master for the adhesive)
Even though weber say weber-joint is okay for showers (And even swimming pools), the grout seems to soak the water straight in, as you can tell by the way it changes colour. Is this okay? If not, should i seal it somehow? perhaps with a mild coat PVA mix?
Thanks for any info....
