Grout floor tiles before wall tiles?
16 Mar 2005
I am doing floor tiles + wall tiles in the bathroom.
Floor tiles are nearly finished.
Is it wise to grout the floor tiles now? There is still a lot of dust and stuff which can fall to the floor when I fit the wall tiles.
On the other hand, I am fitting WC and basin. So I need to grout the floor tiles under these.
Mike
I would have tiled the walls first before tiling the floor unless there was a special reason not to.However,since you have already done it,I would not grout the floor tiles until you have finished the walls.You would probably get away with grouting under the WC and Basin.Cover what you do grout with masking tape once the grout has set, and that will keep it clean meantime. but i'd leave the rest till after.Don't leave masking tape on too long,and keep it dry.
Roughcaster.
Mike,
Forgot to mention.When grouting under you wc and basin,and if your grout is a coloured one,don't grout out too far beyond them.Sometimes,you might see a slight colour difference between the two applications.Keep it tight to the shape of the wc and basin pedalstal, plus say 2 or 3 mm,no more than that.That will also save you having to mask up as well.A neat bead of silicone around them both will finish it off perfectly.
Roughcaster.
