- Joined
- 13 Oct 2009
- Messages
- 85
- Reaction score
- 0
- Country
Tiled a kitchen splashback with metro tiles 20cm x 10cm, 2mm spacers.
You probably know the ones, but they are bevelled.
Used a flat tile float to apply grout and then removed using a wet sponge. However, I now realise I should have really pressed into the space between the tiles, which I didn't.
So I'm left with a grout line of approx 5mm. This was yesterday. It doesn't look awful to my eye, and the widths are fairly even, but I now realise from looking at pics that I should have pressed in and got 2mm lines.
I used Mapai coloured jasmine grout.
So, this was 24 hours ago. Should I leave well alone? Of can I rewet the grout and try and take it down to the place it should be. I'm not sure if this is possible, how long it would take, and whether it would end up looking worse? Its about 7m in length, 4 tiles high, so I suspect it wouldn't be a quick job.
Thanks in advance.
Thanks in advance.
