I'm tiling my 'u' shape enclosure (800 x 1200mm) with 400mm x 400mm x 10mm natural slate tiles using brick bond. My questions are:
1) Where to start - I was going to tile the two outer walls first, starting from the bottom (full tile height as the tiling is going up to 2m), marking out the centre then working upwards. When these two walls were done I was going to tile the back wall from the centre out. Is this right? If I am using brick bond then I will have to go up in rows rather than columns, is that right?
2) When it comes to the internal corners I was going to cut the slate so the two side walls butt up the the back wall, then when tiling the back wall leave a 3mm silicone gap, is this also right?
