Grouting question
24 Sep 2004
Hi, I have just finished tiling our bathroom with the small mozaic tiles but before I start grouting I have a quick question.
Whats the best way to grout without having to go along each row to smooth and even the grout lines out. Obviosuly I could spend the next 6 months doing so, but is there a simpler way that would make it easier.
I though about leaving the grout to start drying and then wiping over with a damp sponge? Any suggestions would be appreciated. Thanks.
Mix your grout as it say on the manufacturer instructions then work it into joints with a grout float, give it a little while then wipe grout from the joint with a damp sponge, rinse your sponge often to keep it clean. Don't worry about the slight grout smear on the tile that can be easily wipe off with a dry cloth when dried.
why not try caulk.goes on with no mess,dos'nt shrink,waterproof and can be wiped off.also can if need be ,be painted.
