My combi boiler has a Grundfos 15-50 pump. The pump has just started making unusual noises intermittently and varies in volume. Not sure if it is racing or jammed or has dirt in it but seemed very hot when touched. I can hear a hum sound and can feel it vibrating so could be working. Hot water isn't getting to the radiators and boiler is cutting out. Pump is running on setting 3.
Is there a way I can check myself if there is a problem with the pump. If it is jammed can be freed, if there is grime in it, is it easily removed.
My neighbour suggests removing the silver cap at the front of the pump and inserting a screwdriver to test if is jammed. Not sure I trust him - would boiler have to be drained to do this.
Looking for advice.
Looking for advice.
