- Joined
- 31 Dec 2003
- Messages
- 173
- Reaction score
- 1
- Country
My Boulter Buderus Camray boiler has shutdown and I think it may be a failed pump. It has a Grundfos UPS 25-60 pump fitted and I removed the large screw to check if the impeller was rotating. From past experience I would expect a steady, but not powerful, stream of water to run from the bottom of the screw hole but I am getting a thin, powerful, jet of water coming straight out of the middle of pump shaft - it almost looks like there's a hole or depression in the middle of the shaft - there is no keyway so I can't use a screwdriver to try to free it up.
When there is power to the boiler it sounds like the pump is running but as soon as the boiler is actually switched on it locks out.
Grateful for any advice.
