Grundfos pump installation
24 Feb 2008
London
when fitting a new grundfos pump, 15-50 (like for like replacement) do the wires go into the junction box in the bathroom in a certain order? is this a standard order for all systems ? will the new pump have instructions on this ... ? is this easy to do? thanks all for your advice!
yes i know they go into the pump!!! but they also go into the junction box on the wall (plactic with a screwed cover)!! the cylinder stat and three port mid pos valve also go into it as well as other leads. !!!
you dont have to disconnect both ends to change a pump
Yes. The wire goes between the pump and junction box, this is what I do.
No need to renew wire, easily get lost in maze in junction box. Just replace pump and refix wire.
Dan
i know but i want to learn how to do it properley!!! apparently it's basic plumbing electrics!!! just wondered how its done! :)
doing one end is proper, unless you're thinking of rewiring the house because the pump is shot!!!!!
ok than ks for your help. i just wondered what order the pump connected into the junction box and if there was a set way. i know the numbers go from 1-8!
Asks a lot of questions for someone JUST interested in diy and goes looking at his mates airingcupboards.
just trying to learn more from you pro's!!! :D nothing wrong with that is there!!?
Nothing wrong at all with that as thats why we post here. but something don`t add up. but hey you might be genuine.
