Grundfos pump setting? Constant or variable load heating sys
24 Nov 2009
Bedfordshire
I've just replaced my Grundfos alpha heating pump and it has settings for constant or variable heating systems, but I have no idea what this means. I have a megaflow system and gas boiler, any ideas?
thanks
Which Alpha - 2 or 2L?
You should normally leave it on the default setting, i.e as it comes out of the box.
Yes its a alpha + and the default setting is variable load with normal resitance. Reading on http://www.pumptool.co.uk/Types.html seems to explain the pump speed better and I think I'll leave it on the default unless it doesnt appear to be powerful enough.
