Hi There,
I have a problem which i think is a faulty grundfos selectric 15/60 pump. My boiler periodically fires up, but then turns off a few minutes later. The pump is making a loud rattling noise. The pump itself is hot and also the pipes either side. I have read about turning the shaft but the info is not clear regarding the screw on the front being a bleed screw? I have unscrewed this half a turn to see if water is coming out and it does, but is it safe to access the shaft by removing this silver coloured screw? Also, is it worth doing this as there has been hot water (but not any more because the boiler wont fire up). I have also set the the speed switch to "2" as it was on "3" but no difference. Does this sound like a classic faulty pump problem?
Any help would be greatly appreciated.
Cheers, Rob
Cheers, Rob
