I'm a new member so please forgive me if I'm asking a question that's been asked before. I've a hot-water system using a GRUNDFOS SELECTRIC pump. Just above and below the pump there's what looks like a screw on collar. Next to each collar there's a small on/off valve; turn it 90 degrees one way or the other and the water turns on or off.
The pump rotor sounded as if it had picked up a bit of grit or something. With the valves turned off I pulled the pump body. No problem with the rotor. It all went back together and sealed ok but when I turned each valve back on they both leaked. Not a small leak; a fine water spray. I don't know if the valves unscrew but they don't seem to. After turning each one on and off a few times they stopped leaking but only when turned off. Very sensitive; turn the valve a fraction and it starts to leak.
Can anyone give me advice please? It's as if they have internal O ring seals which over time have become brittle.
