Hi. Had this for 7 years. Worked flawlessly until now.
Often when turning hot or cold tap on or shower, the pump will not start, it just buzzes loudly . To get it to work, the power is turned off then on and it works fine then.
It is intermittent.
Do you think its electrical or pump fault?
I checked circuit board and can see a relay. You reckon it could be that?
It is intermittent.
