Hi I've replaced the pump with a ups2 and it's much quieter, however it still won't shut off lije the old one.
Central heating and hot water controls are both off and thermostat is turned down but pump is still running and boiler if firing up. Even when I switched off the boiler directly the pump still runs.
I think the issue is the 2 way central heating valve (there are 2 honeywell). Likely to be the microswitches stuck.
Would you agree and is there anyway to shut the pump off without shutting the ring main its hard wired to? Thanks
