- Joined
- 2 May 2021
- Messages
- 18
- Reaction score
- 3
- Country
Hello
doing a garage conversion to granny annex, soil approx 30 mtrs away, installed new manhole and connected 4 inch pipe to existing drain, for rodding and inspection. have buried 40 mm solvent under ground. Basically from macerator, direct 300 mm drop, level for 25 mtrs, then 45 degree rise 300 mm then 3 mtr run to falling 4 inch underground pipe to main drain.
Pipe from new manhole to garage loaded with water continuously, tested out with hose running into pump and can see a nice push (burst of water running to drain)
all seems well but a bit concerned or more so (don't like the thought of poo sitting in a pipe just hanging around to be pushed through to drain when shower, sink or loo is flushed )
just wanted to know if anybody can see any problems with install, or foresee any problems with install. Many thanks
