I am trying to fit some GU10-style downlights - I have done 4 successfully (or rather my electrician has). The fittings are JCC "JC2009" fittings, which take GU10s, 50W, mains (no transformer). The holes in the ceiling are 85mm diameter.
The problem is that the required void depth is 135mm, and in the remaining two holes, I have a wooden joist only about 60mm above, so these fittings aren't even close to, erm, fitting. My electrician tried to find a suitable alternative, but has drawn a blank.
Can anyone give me any suggestions? The 85mm holes are already cut with the joist 60mm above. Obviously I could "build out" below the hole, but I don't really want these "recessed" fittings sticking out. I'd like to avoid the whole transformer and low-voltage solution if possible.
Are there any "low profile" (and/or low-wattage) fittings that could work?
Thanks for any suggestions.
